How to draw the state diagram for a divide by 5 circuit in FSM
SKS
Junior Member level 3
How draw the state diagram for a divide by 5 ckt????
A.Anand Srinivasan
Advanced Member level 5
India
Re: Problem in FSM
tell about the input and output... and the constraints on the input and output.... make ur question a little more clear if possible........
SKS
Re: Problem in FSM
Input is a continuous bit stream and the output is also a continuous bit stream
A.Anand Srinivasan
India
Re: Problem in FSM
what i wanted to know is if the input is say some 01110100101010 then what is the output because for divide by 5 some count the number of 1's some the no of 0's and some will output the 5th bit etc etc...
kpsai26779
Member level 4
Bangalore, India.
Problem in FSM
Hi SKS,
Can you explain ur problem in detail, like ur sequence is finite sequence (fixed length) or infinite sequence.
if u r giving example then it will be very helpful to answer ur question
SKS
Re: Problem in FSM
ok...
suppose input : ....1011011010 (LSB first)
output : .....1001001000
so whenever it encounters a sequence a multiple of 5 it gives output 1...
kpsai26779
Member level 4
Bangalore, India.
Problem in FSM
Hi anand,
ur FSM is working good for 101, 1010 but not 1111, 11110
Thanks & Regards
    V
A.Anand Srinivasan
India
Re: Problem in FSM
the user has said that he wants to detect 101 and 1010 so when as you said if 1111 or 11110 occurs you would find that it has gone to state S2 which considers that a 1 has occured and for the latter case to state S3 which considers an 10 to have occured so it will work fine....
A.Anand Srinivasan
India
Re: Problem in FSM
for no other transition the output will become 1.... the 1 represents the occurence of 101 or 1010....
    SKS
