sunrisesky
Newbie level 3
As you known, the data output of memory maybe is the high impedance. When the high impedance is transferred to the following logic, can it result in high current? I’m not sure.
In general, how to avoid the high impedance to transfer? I mean, if the data output of memory is Z state ( The memory is not enable to read or write, Memory Enable active), how to do these outputs? Leave it as it is, or use wrapper to output 1 or 0 using memory enable signal, or use BIST logic? I don’t understand. Would you mind tell me your suggestion? If you are in this trouble, how to do it?
Thank you very much.
