How to do THD simulation of fully differential op?
shaq
Full Member level 5
opamp thd simulation
Dear all,
How to do THD simulation of fully differential opamp in Hspice.
My circuit architecture is shown below.
pfd001
Advanced Member level 1
thd op
u can run transient simulation and do fft
shaq
Full Member level 5
thd design architect ic
Hi, pfd001
Can you or others expain it clearly?
nagag
In case of spectre you can do in this way.
Now this is in unity gain configuration and so you can run a transient with a large signal and then select THD option from the waveform viwer.There you need to specify the fundamental frequency.It will give you hormonic distortion interms of percentage.
