Re: how to do mixed signal simulation in spectre using netli
Some of the verilog models are available in the veriloga library provided by cadence. You can also create your own veriloga models and create the symbol for the model. You can instantiate these symbol in composer and simulate as usual.
hi to all,
i want to know how to use netlist of analog parts with netlist from verilog code which is written for digital parts ... using these netlists can i do mixed signal simulation in artist or someother tool....
I m not talking about using verilog models... i want to use actual circuit (netlist) for simulation.. can i?
Do you mean the synthesized SPICE netlist from the verilog? If you want to mix SPECTRE and SPICE, you can use the simulator lang=spice option when you start the SPICE netlisting and then shift back to SPECTRE.
I think you must use spectreverilog to do it . Spectreverilog actually use spectre simulate analog netlist and use verilog-xl simulate verilog file. And you must produce symbol of the verilog block. You must put A-to-D and D-to-A model between analog block and verilog block. This is a mixed signal simulation reference by spectreverilog. It is very detailed.
It is indeed possible to use spice netlist generated from verilog code and simulate it together with analog blocks. You can create a symbol to represent the spice netlist, modify the CDF parameters, and include the digital cell spice netlist in the model library. Then you can run the simulation. I have found a detail explaination from this link as I am trying to run mixed signal simulation using digital cell spice netlist with analog blocks.
