Hi:
I have known the function of set_max_fanout,but I don't understand how to confirm the parameter which following set_max_fanout.is this parameter determined according to target library. please help me!
thank you!
parameter for the set_max_fanout is value and port or pin list, syntax set_max_fanout value port|pin list
but i hope so thats not your problem you need to know which port or pin need to be listed and why?
if its not please highlight your question
I want to use the set_max_fanout to constraint the fanout of the net in the internal circuit,but I still don't understand how to confirm the parameter of set_max_capacitance.I just want to know in which case use the set_max_fanout and set_max_capacitance.
thank you!
