How to determine SFDR, SNR, SNDR of ADC with LTSpice
kickbeer
Full Member level 3
sfdr importance in adc
Hello,
The standard SFDR is 48dBc. What does it mean, when SFDR is higher than 48dBc or lower than that value?
Thank you very much
Regards,
Kickbeer
JoannesPaulus
Advanced Member level 3
USA
sndr adc
SFDR is defined as the ratio of the RMS value of the carrier frequency to the RMS value of the next largest noise or harmonic distortion component.
    kickbeer
kickbeer
Full Member level 3
noise sfdr
so, does that mean the higher the SFDR, the better it is?? Because the higher the noise, SFDR will be lower
JoannesPaulus
USA
snr for adc
Correct. SFDR is a measure o linearity.
I do not know what you mean.
    kickbeer
kickbeer
Full Member level 3
adc simulation sndr matlab
I'm simulating my ADC with LTSpice. I took this from an article:
"To determine a system’s SFDR, apply a sine wave to your ADC input and use an appropriate sample rate.Then run an FFT and examine the spectral output. You can see the fundamental frequency and “spurs” from harmonics of the test signal and system components. I recommend you make this test at several sine-wave frequencies and sample rates."
Do you know, how many times(minimum) should we apply sine-wave with different frequencies?
Petre Petrov
Member level 3
Sofia
ltspice maxim
May you should take at least 20 experiments with different values.
The requirements about the experiments/simulations depend on the test goals.
Also here you have some explanations:
https://en.wikipedia.org/wiki/Spurious-free_dynamic_range
But the term and the source seem to me controversial.
Could you please give more data about your paper and test goals?
kickbeer
Full Member level 3
wiki sfdr
I just have designed a 8-bit folding and interpolating ADC. In order to check the static performance, i have put a ramp input signal and found out that there is no missing codes. Now i want to know test the dynamic performance for example the SFDR at simulation level. I really don't have idea how to record all the data and use it in matlab. I don't know if it is easy or not because i am matlab beginner. I think all the article in Maxim website are for fabricated chip. I really need help because i am stuck at this point. Thy very much
JoannesPaulus
USA
rms ltspice
you need to figure out how your simulator can write text data to a file (I have never used LTSpice so I cannot help you here) then you can use matlab to read the text file in and create a data vector that will be processed by an fft function to give you the adc output spectrum.
Once you have the spectrum, you can calculate the SNR, THD, SFDR, and so forth...
The learning curve might be a little steep but knowing the basics is fundamental in circuit design...
    kickbeer
ozgura2
Turkey
ideal sfdr of a dac
You will do a transient simulation, assume sampling with a 500MHz clock, fsampling is 2ns. For 8-bit performance 256 data points is sufficient for FFT. Do a minimum 256*2ns (512ns) transient simulation. Input sinus frequency should be (127/256)*500M. 256 is FFT points 127 is a prime number. For this case input frequenccy is near Nyquist frequency, you can decrease it. After tran sim use Cadence's dft calculator function. If you are using other tools there should be fft function similar.
    kickbeer
    V
kickbeer
Full Member level 3
sndr from dft
Is there no need to connect my ADC with ideal DAC or something else? Can i just use my ADC alone? Look at this **broken link removed**
Added after 6 minutes:
Hi Joannes,
Have you ever worked with Matlab before? i have just found a Matlab Code to convert .raw waveform file into compatible matlab data. i have successfully converted the .raw data(output of my ADC) into matlab compatible data. but now, i don't know how to use the data to calculate parameter like SNR, SNDR, and SFDR..I really have no idea at the moment
ozgura2
Turkey
sfdr of adc
I use binary weighting of digital output data at Cadence calculator like (BIT<7>*2^7+BIT<6>*2^6...) Of course you can use an ideal DAC also. DFT will sample discrete points of this summed data.
    kickbeer
kickbeer
Full Member level 3
ltspice for chip design
Can you show me the snapshot of your simulation result? And what type of ADc you have designed?
