how to detect high current flow in circuits ?
ringo888
Member level 1
current sensing
Evening Gents,
Can anyone explain to the how to detect high current flow in circuits, I believe a low value resistor is used? does anyone have any suggested circuit examples?
Regards,
Ringo888
current sensing
current I = V/R
using approximate ragne of expected current, select suitable low value of R to allow measurement of voltage across it with the instrument you plan to use.
Raoof
Re: current sensing
Inserting a resistor with a small known resistance value is a simple solution, but it will lead to additional power loss.
Alternative solution, avoiding additional power dissipation, is to select two points in the metal routing, along the direction of the current flow, and measure a voltage difference between these two points. This voltage difference will be proportional to current. You can find the proportionality coefficient (i.e. effective resistance between these two points, corresponding to current density distribution for operating condition) either from test structures and measurements, or from simulation of the current flow in your metal interconnect system. Depending on the complexity of the metal layout, you can estimate the resistance between the two points analytically ("by hand"), or you might have to use a field solver in the case of complex layouts.
Re: current sensing
App notes on current sensing.
Here's a another interesting one about magnetoresistive sensors:**broken link removed**. E.g. ZMC05 and ZMC20 current sensors.
Allegro Hall-effect sensors, which were already mentioned above: **broken link removed**
What kind of current do you have:
- AC or DC? If AC, what's the frequency?
- Do you need to know instantaneous current? rms?
- Do you want to measure current, or just detect when it's above some threshold?
- What's your expected range of amps?
- What's the voltage at the point where you want to detect current?
    ringo888
Re: current sensing
Thanks guys for your responses much appreciated, The app note links look very interesting.
Kender:
No there was no specific measurement just a general question, i'd ideally want to have a current sensing limit that would then switch a FET or BJT trans that would then go to a micro, something like anything greater than 1A. any suggestions on circuits?
Cheers Ringo888
