I agree with whizkid
Very high fequency chip, It is easy to design with method of analog.
The synthesis method is very difficult when your design is very huge.
I found out that it is very diffcult to implement a programmable counter(bit 2), that is the divider can be 1,2,3,4 , and output clock duty cycle is 50% at 0.09nm process for 960MHz.Because I must use both the posedge and negedge. The slack is about -30ps.
