[SOLVED] How To Delay 100ms From One Output To Other Output In Vhdl
sanju_
Full Member level 3
BANGALORE
Hi.
I have four output ports (A,B,C,D).
i am sending serial data as output four outputs at a time.
now i want to send second serial data to same output ports after 100ms of first output...
is their anyway i can do using vhdl apart form WAIT statement...
thanks
the wait statement is only appropriate for simulation.
Otherwise stick the data into a memory and use a counter to wait for 100ms.
100ms is a very long time to wait, you may need a BIG buffer to cope with all the backed up data.
Reactions: sanju_
    sanju_
yeah thanks thought of using counter it self...
didnt get what exactly "BIG buffer to cope with all the backed up data." means
You wont need it if there is no more data coming from the serial port.
Reactions: sanju_
    sanju_
one more thing i am sending serial data of different type like i did serial shift as output next output is different
from first serial data that i need to delay it for 100ms
in between this two output how to assign counter
as i done shift register output as first output may be same output at second but delay need is 100 ms
any sample code or line for delay part??
IF (count2 = 2 AND temp = '1') THEN
count1 <= count1 + 1 ;
TEMP1 <= TEMP1(8 downto 0) & '1' ;
TEMP2 <= TEMP2(10 downto 0) & '1' ;
TEMP3 <= TEMP3(10 downto 0) & '1' ;
TEMP4 <= TEMP4(19 downto 0) & '1' ;
count2 <= 1 ;
END IF; --------------> shift register part
IF (count1 < 20) THEN
A <= TEMP4(20) ;
IF (count1 < 11) THEN
B <= TEMP2(11) ;
C <= TEMP3(11) ;
IF (count1 < 9) THEN
D <= TEMP1(9) ;
ELSe
D <= '1' ;
END IF;
ELSe
C <= '1' ;
B <= '1' ;
END IF;
end if ; -------------------> output part
output part repeats again how to introduce delay between them
thanks TrickyDicky...
i used counter for delay and used "case" statements at the output side its working fine now.
may i know how have you done the delay and the case statement?
i am facing the same problem like u had before.
can u send me the coding?
Thanks for your big big help.
:wink:
