How to define a one bit from an std_logic_vector?
alexz
Full Member level 5
UK
Is there a way to define a one bit from an std_logic_vector?
something like that:
myport : inout std_logic_vector(15 downto 0);
define mybit myport(0) ;
now I would use "mybit" instead of myport(0) .
Also, what is the way to do that with literal numbers?
define aaa 15
or
define bbb '1'
Re: VHDL basics question
Well I looked in all my VHDL books and I couldn't find a way to do it. Personally, I think it's not possible but I may be wrong.
define aaa 15
or
define bbb '1'
You may use constants:
constant aaa : integer := 15;
constant bbb : std_logic := '1';
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY multiplexer IS PORT (
d0, d1, s: IN STD_LOGIC;
y: OUT STD_LOGIC);
END multiplexer;
ARCHITECTURE Behavioral OF multiplexer IS
constant aaa : std_logic := '0';
BEGIN
y <= d0 WHEN s = aaa ELSE d1;
END Behavioral;
I think u can't define a single bit from ur port declaration....
For literal nmbrs, u can use constants.... which is similar to Parameter in Verilogeg
Eg:
constant unit_delay : Time := 1 ns;
I think I have found a way of doing it...
That is ALIAS
SIGNAL myarray : std_logic_vector(31 downto 0);
ALIAS mybit : std_logic is CANdataIn(0);
mybit can be used as the LSB bit of myarray
yes i think its possible when u define like
myport : inout std_logic_vector( 0 downto 0);
because in case of xilinx cad tool we can specify like this...
What is the point?
myport : inout std_logic_vector(0 downto 0);
i think the above declaration may be used..just check it once..i am not confident...
