I had tried different version of Synplify 7.0, 7.1, 7.2, and 7.3.
I found out the time slacks are getting worst as the version evolves.
The design that once pass the timing constraints in 7.0 (15MHz)
now has slack about -5ns in 7.3.
Is there any additional settings I need to take care of?
Remember that Synplify is just making an estimate of what the timing will be - it's not until you run it through the FPGA vendors PAR tools that you get the definitive answer. Has the PAR timing changed across the revisions?
Also, if you are targetting a new FPGA/PLD architecture it could be that the FPGA vendor has revised their characterisation data of the device, and this is being reflected in the different results you are getting...
I suggest you an icremental approach to synthesis... The first time try oversetting the clock frequency (e.g. 200 MHz) and get the estimeted clock frequency. Then do a new synthesis step with a new clock frequency near to the previously found (use a little bit higher frequency than the former found one)
