How to declare the byte variable at header file?
Help
Advanced Member level 2
a.c
union Data
	unsigned char nbit;
bdata struct Bit
	union Data byte;
}Ex;
sbit xbit0 = Ex.byte.nbit^0;
sbit xbit1 = Ex.byte.nbit^1;
sbit xbit2 = Ex.byte.nbit^2;
sbit xbit3 = Ex.byte.nbit^3;
sbit xbit4 = Ex.byte.nbit^4;
sbit xbit5 = Ex.byte.nbit^5;
sbit xbit6 = Ex.byte.nbit^6;
sbit xbit7 = Ex.byte.nbit^7;
a.h
extern bit xbit0;
extern bit xbit1;
extern bit xbit2;
extern bit xbit3;
extern bit xbit4;
extern bit xbit5;
extern bit xbit6;
extern bit xbit7;
Does anyone know how to declare the "nbit" valiable as global variable? In the a.c file we can easily assign the valiable to
Ex.byte.nbit = 1;
but i don't know how to declace the Ex.byte.nbit as global variable and use it in other .c file.
Thank you.
btbass
Advanced Member level 5
Oberon
Bit Addressing
Declare it as extern in a header file and include the header file in the c files that want to use it.
    Help
Help
Re: Bit Addressing
Hi btbass,
Thank for your reply. Yes, what you have spoken is rite but how to declare the byte variable at header file? Please have a look in the attactment.
Thank you.
btbass
Oberon
Re: Bit Addressing
It seems that you might be better off using bitfields.
/* stick this in a header file */
struct mybitfield
unsigned bit_0:1;
unsigned bit_1:1;
unsigned bit_2:1;
unsigned bit_3:1;
unsigned three_bits:3;
unsigned bit_7:1;
typedef union
struct mybitfield bits;
unsigned char thebits;
}BIT_UNION;
extern volatile BIT_UNION Bit_union;
/* declare instance in a c file */
/* use like so */
Bit_union.thebits = 0;
Bit_union.bits.bit_0 = 1;
Bit_union.bits.bit_1 = 1;
Bit_union.bits.three_bits = 7;
/* etc */
/* Or passed as a pointer */
Bit_union->thebits = 0;
Bit_union->bits.bit_0 = 1;
If you just want to set and clear the bits, you dont need a union.
typedef struct
unsigned bit_0:1;
unsigned bit_1:1;
unsigned bit_2:1;
unsigned two_bits:2;
}MYBITFIELD;
extern volatile MYBITFIELD My_bits;
My_bits.bit_0 = 1;
My_bits.two_bits = 0x03;
My_bits.three_bits = 0b010;
/* etc */
    Help
