How to decide the value of sample capacitor
Jenifer_gao
Member level 1
Hi All:
If I design a sample and hold circuit for an A/D converter, for example, the A/D converter has 10 bit resolution. How can I choose the proper value for the sample capacitor.
Any suggestion will be appreciated. Thanks.
J
Its value is a trade-off between noise and speed performance. Since the thermal noise power is proportional to kT/C, larger cap will decrease the effect of thermal noise, but unfortunately it will increase the load of your op-amps or buffers..
I would just try different values and make adjustments, based on the results. You don't have to design everything analytically. Also, if you're using a unity-gain sampler, increasing the sample capacitor affects the speed, but improves precision.
size of your sampling cap depends on what you're trying to do with switching cap. For example, if you're emulating an resistor then Req = 1/(C*Fs). If you're implementing an inverting integrator, gain dictates the sampling cap (Ki = -(C1/C2)*Fs and so on.
So can anybody give an example, 1pF or 100fF?
