How to decide the power bus width?
panyi
Junior Member level 1
Re: power bus width
EM and IR drop is important
In our company's IP, ADC DAC and PLL's IR drop should lass than 10mV.
carlson
Member level 3
Re: power bus width
electric migration(average current) : normally 1mA/um
IR drop(peak current)
power bus width
Hi all,
Can some one explain or share document on what is electromigration and IR ?
Thanks.
piao
Full Member level 4
power bus width
IR -- IR drop.
you can search on the web for the definition of electromigration.
sometime you also need to take into account of the self-heating.
Beerkaah
Newbie level 5
power bus width
On the topics of Electromigration You have a description in Your Technology Manuals.
(at least UMC013 and TSMC018 Manuals have a section about the topics)
Or use the Bible ! ;-))
(Hastings: The art of analog layout)
May I ask what is the technology that You use ?
forkschgrad
Full Member level 5
Philippines
Re: power bus width
electromigration is one of the topics that is important to understand in IC design. a lot of books and sites that discuss what it is. you can also refer to the friendly wikipedia.
manish12
Advanced Member level 3
Re: power bus width
use 1mA/1um ,and use top metals for pad connection ,metal width should be at least 4? .
? = 2 * technology
Hunter_BJUT
Member level 2
power bus width
1mA per um, leave sufficient margin
climber73
Europe
Re: power bus width
For power and gnd don't use minimum width in according with electromigration rules.
Bye
penchal_gv
Re: power bus width
Width of Power Metal line depending on Electro Migration(EM) and IR Drop.
These EM & IR depend on process and technology. The current density and resistance are different for diferent metal.
Regards
Penchal
