How to create .dll files using compilers?
swapgo
Full Member level 2
India
hi all
Regards
Gopi
Re: How to create .dll files
Good day
The compiler that you use can be set to target the code to a .lib, .exe or .dll
Typical compilers are C++ , Delphi , Clarion ........
Good day
If you are using Visual C++ you can start from the top menu ...
FILE
NEW
(Choose poject type tag)
* for MFC chose : MFC AppWizard (dll)
* for non MFC choose : Win32 Dynamic-Link library
A dll have a dllMain entry point (for initialization for instance) and entry points for exported (public) functions.
Please provide some more detail in order to provide you with usefull information.
how to create .dll files using borland Turbo C compiler.
thanks
Waqas
A Windows DLL? Turbo C? Oh my! Please do yourself a favor and get a modern Windows compiler.
I like free stuff, so I use MinGW. If you don't like command-line tools, you would probably prefer Microsoft Visual C++.
making dlls is veryyyyyyy easy like a hello world prog in .NET
kareja
please see the compiler otinons... are you sure you will use TC?Why to use some modern compiler?
hi,
u cannot create .dll with turbo c compiler, turbo c compiler was not meant to program windows, hence buy ur self a windows compiler and read the documentation.
Can you help me, too?
How to create DLL file in the Borland C++ 5.5.1 for Win32 (free command line tools)?
I study C++ language.
I study English language.
I use usually the VC for designing DLL files.
It is very easy and convenient. you can also refer to the MSDN.
DLL file stand for Dynamic Link Library. It contains the code that is to be loaded by the main program. The purpose of DLL file is to reduce the memory space consumption of the program. You can use either Visual C++ or Borland C++ to compile your code into DLL file.
Hi all
Do you mean to say that any file to be converted in to .exe can also be converted in to .dll file Please clear this
Regards
Gopi
hi all
Or .DLLs are like components.
Regards
Gopi
swapgo said:
hi all
Regards
Gopi
Even in Visual Basic you can make DLL's but keep in mind when you make VB DLL these DLL's are dependent to VBRUN's.dll libraries themselves.
VB is ok to build some apps but in case for building DLL's in Windows C++ is most prefferable method.
swapgo said:
Hi all
Regards
Gopi
hi,
DLL can taken as dynamic header files ;).Like in turbo C u use stdio.h and compile the program and what happens there is that the dependant modules and your program module gets linked to get an executable.That way to execute your program u dont need any other components to be loaded alongside.But the drawback is that suppose you have 10 programs written in turbo C using the same blah blah function from stdio.h,and when u execute them at a time then u ll have 10 copies of thaat blah blah fucntion.SO memory wastage.So they came up with the load time dynamic linking(some runtime dynamic linking) in the form of DLLs.The DLL will have the loadable module fo tat blahblah function and will be common for all the 10 programs.Am I clear??
regards,
Kareja
to add to this statement by the above user I need to stress something.
Before you use it, need to know how to call this function. For an individual work with 2-3 libraries, by you or using someone's .dll file, you can find out yourself by examining the library API calls. If we are talking for numerous libraries you need some help file to know how to call them properly. if you plan for someone to use your library build a good documentation.
