how to create aSG3524 in proteus 7 professional
tarq
Newbie level 3
Any one in forum reply in detail for creating SG3524 in proteus 7 professional.Thans
You can find tutorials for creating the package for schematic. I can help you with that as well.
But if I understand right, what you want isn't just to draw the SG3524, but to simulate it as well. So, you need the model file for the SG3524. I haven't come across any SG3524 model for Proteus (there may be ones around I don't know of). Without the models, the package you create is useless for simulation.
Hope this helps.
Tahmid.
I have downloaded it. Now I just need to put this into Proteus. I've seen in some places that you need to write a C++ code for importing it to Proteus. Do you know about this?
you need to write a c++ program if you want to simulate yourself the behavior of your component
if you already have a spice library, you can use a command like this in the text properties of the component
extracted from the proteus vsm sdk :
PRIMITIVE=ANALOG,SUBCKT
SPICEMODEL=LM741/NS
SPICELIB=NATOA
TheSPICEMODELpropertyspecifiesthenameof theSPICEmodel tousewhilsttheSPICELIB
propertyindicatestheSML(SPICEModel Library) filethatcontainsit. If theSPICEmodel waslocated
inanordinaryASCII SPICEfile, youwouldusetheSPICEFILEpropertyinstead.
Reactions: Tahmid
    Tahmid
Hello Kripton2035,
I followed a bit,plz explain the same in somewhat more detail to follow it easily if you don't mind.Regards
here you have all the explainations to create a component.
it depends if you want an analog, a digital, or a spice component
the spice is the easyiest see the pdf.
regards.
  • Proteus_VSM_DSK.pdf
Reactions: Tahmid
    Tahmid
