How to create a RAM block without using a clock?
Re: RAM Block
yes, that's called asynchronous ram
Re: RAM Block
thanks for ur reply . Is it really possible.
suppose i want to write continuously for more than 5 times. how long i want to make my write enable high.
Is there any possible that junk values enter the memory.
Any synchronization problem. if any means how to solve that
Re: RAM Block
Dual Port RAM Asynchronous Read/Write
see the above link.It is possible to read/write the RAM without a clock.But the necessary signals like Address,Data_in etc has to be generated and supplied to the RAM block.This will need a clock.
May be you can try something like this(I am not sure about whether it will work or any possible glitches):
type RAM_t is array (0 to 255) of integer;
signal RAM_t : RAM;
process(clk)
for i in 0 to 3 loop
RAM(i) <= data_to_be_written(i);
end loop;
end process;
check if 4 values are written to RAM at a time.May be this is a dangerous scheme.But anyway you can check it.
