vcd2vec
Dear all
I have a digital design writen in verilog .
after synthesis, i want to simulate in the transistor level using nanosim .
and i've translate the verilog netlist into spice netlist using nettran command in hercules .
and I want to also translate the testcase written in ntb in to spice stimulus or anyother vector file that
nanosim can recognize .
In general , my OVF( Original Vector File ) is testcace in ntb
my TVF( Target Vecyor File ) is spice stimulus or other format that nanosim can recognize
I have looked up to VTRAN , but it seems that it can't deal with my problem , it can translate
verilog-testbench in to ns-sported vector file.
thx in advance
,what should I do then ?
Added after 4 hours 17 minutes:
hello all :
I looked up in the nanosim userguide , and found the vcd2vec command .
i'll try this command .
and i know vcd files contain both the test vector and response .
i wonder if i get the vec file ,whether it also contain these all , and can verify if the design have the right
response in transister-level through nanosim .
Added after 1 hours 45 minutes:
I found the vcd2vec command , vcd2vec <-d > -nvcd vcd_file <-nsig sig_file> <-nvec vec_file>
but i can't find any more information about this command either in the ns-userguide or command-reference .
because i'm a newbie , i don't know what is the signal information file .
how can i get the file , or how can i write such a file .
i use vcs simulator , and generate the vcd file , can i generate this signal information file also by vcs , how ?
thx all .
