How to convert .hex file to .asm file?
bergkamp
Newbie level 5
help BEGINNER
i have a .hex file for a micorcontroller and i want to turn it into the assambler code. do you know any application that can do this?
thanks!
wek
Full Member level 4
disassembler hex to asm
This kind of tool is called "disassembler". Of course, it is dumb, and you might need to reconstruct data areas etc.
Which kind of microcontroller is your hexfile for?
wek
    bergkamp
wek
Full Member level 4
18f2620 disassembler
If your microcontroller is 386-based, then yes.
But I think it is not too probable.
Again: what is you microcontroller?
Jan Waclawek
metal
Full Member level 6
desasembler hex para asm
Hello
If you are using PICs MCUs, then you can use ICProg disassembler.
Regards
bergkamp
Newbie level 5
how to open hex file as asm
i am using 8051
IanP
Advanced Member level 5
West Coast
pic disassemblers icprog
There is no simple solution here. You can obviously use disassembler but it will be up to you how to interpret the file created by a disassembler.
Regards,
IanP
wek
Full Member level 4
hex code disassemble
How do you mean?
It is full with sources.
All you need to start is d52.exe (or the d52 elf, it you do Linux), but have a look also at the example (test.ctl and test.hex).
What, if a piece of software today does not have xxxMB it's suspiciously small? :)
The windows GUI is kind of experimental, I don't use it.
Oh, and you may want to read the manual :-o
wek
ful babu
Full Member level 3
Singapore
.hex to .asm
any one kno any PIC18F dassembler ?
thx
asahin11
Member level 3
386 hex to asm
thx
You can use ICPROG for PIC disassembler.
ful babu
Full Member level 3
Singapore
pic hex decompiler 18f4550
i m afraid icprog dassembler doesn't support 18F series
VVV
pic18 import hex file
For PIC's, just open MPLAB, click File.. Import and import the hex. Then click View. Program memory. You will see the disassembled code.
Right click on the tabs at the top and uncheck them all, except "Disassembly".
Select the first line of code, right-click on it and select "Output to file" to save the file as text. Then you open that file and edit it, but again, you need to figure out many unknowns.
ful babu
Full Member level 3
Singapore
disassembler pic18f252
i did as u told so but wen i try to import a hex file it gives a message like "The format of the file cannot be read or written because its extension was not recognised" though the file was compiled by tat MPLAB itself !
VVV
disassembler bin to asm
I do this every day and it works just fine. That is how you program a PIC when you are only given the .hex file, for example.
The fact that it did not work means that the file is corrupted or is the wrong file. Try creating a new one, with only a few instructions, assemble it and then import the hex file. It should work.
Duby
Junior Member level 2
converting hex file back to asm
I don't have any problem with Importing hex file
....thanks to VVV
