[SOLVED] how to convert analog output voltage (3V to 5V and 4.6V to 5V) to (0V to 5V)
maxima_diesel
Junior Member level 1
Hi I just wanted to convert the output voltage of the circuit I have made to a wider range of 0V to 5V. I would need this output to be analog, so the output shouldnt be 0V. OR 5V. I have two circuits, the first one's output range is 4.6V to 5V and the second has a range of 3V to 5V. How would you change those output to 0V to 5V?. Thanks a lot in advance.
The easiest way is to use a comparator.
Set the 'comparison' voltage somewhere close to the middle of the input voltages and the output will swing from one logic level to the other (typically 0 to 5V) as the input exceeds it.
Brian.
Brian.
Hi Brian,
Thanks for the reply, Im just wondering if using a comparator setup like u described would have the analog voltage output that I would want, so the range is 0V to 5V instead of an output of (logic low)0V and (logic high)5V? Do you have any other suggestions? thanks in advance.
You would need a DC level shifter. Have you searched on this?
I think you can implement it with an opamp.
Hope this helps.
Tahmid.
Hope this helps.
Tahmid.
Thank you very much for your reply Tahmid. Do I implement a DC level shifter using a difference amplifier? Is it ok if you can elaborate on what sort of op amp setup i should be using/looking for?
thanks a lot again.
You may try to use a summing amplifier circuit based upon the standard Inverting Operational Amplifier configuration that can be used for combining multiple inputs. See the example:
Thanks for reply mister_rf, I don't think youve posted the example correctly is it ok if u can post it again so I can look at it? thanks again
---------- Post added at 13:04 ---------- Previous post was at 12:52 ----------
In practice need also to use some buffer to obtain Vref.
thanks sir, I shall try it, may i ask what sort of program/software/webiste did u use to create the schematic u just shown me?? i would also like to to try it for the other setup: 3V to 5V converted to 0V to 5V. thank you very much for your assistance
It’s a very small program, TINA Design Suite,
but you can use any simulation software you like…
To solve the problem need to put data into the summing amplifier equation:
V out = V2* (R2+R1)R4/R1(R3+R4) – V1* R2/R1
For the thanks you may use 'helped me' button... :lol:
google it .."op amp circuits" or
generally all u need is a ref volt like mister.. post and use fixed resistors with rotary switch to get several fixed outputs .
install ltspice and u can run any-circuit and get real time scope like voltages
cool thanks, atm I cannot seem to download the demo because I am at uni, is it ok for you to change the input voltage range from 3.5V to 5V and the output from 0V to 5V? and post the schematic here? thanks in advance.. sorry for being a pin and sorry i didnt know there is a help button here.. :S
Summing amplifier equation:
Vout = V2* (R2+R1)R4/R1(R3+R4) - V1* R2/R1
we replace
R2/R1 = x
and
R3/R4 = y
For the new conditions:
Vout = 0V for V2 in = 3V
0 = 3* (x+1)/(y+1) - V1* x
and
Vout = 5V for V2 in= 5V
5 = 5* (x+1)/(y+1) - V1* x
simplifying equations:
5 = 5* (x+1)/(y+1) - 3* (x+1)/(y+1)
5 = 2 (x+1)/(y+1)
5(y+1)= 2(x+1)
x= (5y +3) / 2
if we chose
y= 1
solution:
x= 4
and
V1= 3(4+1) / 4(1+1)= 15/8= 1.875V
