how to convert altium desingner .pcbdoc file to pads file??
ilikebbs
Full Member level 1
import pcbdoc file into pads
now i have successed to import .brd file into altium designer.
the output is .pcbdoc file.
How can i convert the .pcbdoc file to pads file?
thanks in advance.
Anonymous_Ricky
Advanced Member level 2
India
convert altium to pads
hi,
try saving the file in binary 4 version or ascii version fron the save as option as these both have extension of .pcb which is supported by PADS.
one problem that you might have is that some of you design rules will be lost but you might be able to import these files into PADS.
regards,
Ricky
PCBKARTHI
india
Re: how to convert altium desingner .pcbdoc file to pads fil
hi ,
must you have use altium designer to pads converter software in built pads.
