How to convert AC signal in mili volts to DC signal
adnansarwar2050
Member level 2
Member level 2
Islamabad
I am using ACS712 hall effect current sensor.
https://www.allegromicro.com/~/media/Files/Datasheets/ACS712-Datasheet.ashx
It gives 66mV/A. I am using ADC0808 to read the value of AC current passing through real load. Now the problem is that ADC0808 reads the analog values but i need the peak value of current. How can I read this signal with ADC0808. Can any one please help me.
Use an opamp to amplify the signal.
You say you need the peak value.
* Either your sampling frequency is high enough to catch the peak, then you can find the peak with software
* Or you need external analog circuitry to catch the peak...then convert to digital
Can you define the "peak" with timing, voltage and frequency (repeating)?
Klaus
If this signal sinusoidal , you may multiply by 1.41 that is peak value.
If it's not, you should use simple tracking peak detector with a OpAmp.
