we use integrator to get tri wave from a square wave and sine from tri, why don't try differentiator circuit like simple CR circuit similar to high pass filter, but take care of the cutting frequency of the high pass filter, this is a simple method you can use.
It hasn't been said at all, if the sine wave has fixed or variable frequency (which range) and how amplitude variations shall be reflected by the sawtooth.
The sinewave must first be converted into a square-wave by amplifying it a lot and letting the amplifier clip the signal into square-waves. A small sine-wave will also clip the same as a large sine-wave so the amplitude of the sine-wave doesn't matter (as long as it is high enough for the amplifier to clip.
Then the square-wave is made asymmetrical then integrated into triangle-waves that all have the same amplitude.
The input sinewave may have varying frequencies. Would there be a problem if we convert it into square wave and take integral? I tend to believe that the resulting triangular wave would have varying amplitude
circuit will be in this configuration,use operational amplifire in open loop gain,it'll convert sine wave into rectanguler wave then use integrator to convert ur rectanguler wave to trianguler wave
Yes, you are right. The result of integration depends in its amplitude on the duration of the rectangular signal - and, thus, on the frequency of the limited sinus.
Any suggestions to cope with the problem of varying frequencies ?
This circuit is connected to the 120vac power line and transfers 60Hz clock pulses to a logic circuit. The optoisolator used provides 5000 volts of isolation between the power line and the logic side of the circuit.
if you are trying to get a triangle wave, i suggest you to use a circuit like this
it can generate triangle and pulse, with any frequency and amplitude by changing resistors and capacitor.
---------- Post added at 10:33 ---------- Previous post was at 10:31 ----------
i cant send a link...
---------- Post added at 10:40 ---------- Previous post was at 10:33 ----------
