Hi
I am newbie in networking.
I want to connect two remote computers. these computer can share data. how can i do this? the steps involved in this?
please guide me how can i do this. Please give me some refrences.
Are you transferring data between the two computers or something more complex such as remote login? If it is simple data transfer you could use TCP virtual circuits or UDP datagrams to communicate between the two or more computers. However, if they are behind firewalls or in a NAT internal network you will need to do some confirguration to allow the packets thru.
teamviwer is a good software for remoting and cummonication two remot system :wink:Hi
have a look at
The SSH (Secure Shell) Remote Login Protocol
also if you do a web search for "java telnet" it will turn up lots of links
what is the operating system on your target machine? If you intend to run a server that allows remote logon I would assume you would need administrator rights
Hi , every body !
I want access my personal computer which is located at home from my office computer , would you kindly help me in this regard, thanks all
