How to connect the CASR 6-NP current to measure current
miche
Newbie level 1
Newbie level 1
hi,
i'm using a current sensor (CASR 6-NP) from LEM. In the datasheen there is any informations showing how to connect it to a load. I measure between Vout and ground. from now i couldn't detect any voltage change when a current flows. When i use a ammeter i am able to observe the current variations on its display.
i'm thinking that i do something wrong in my connection. you can see it in the figure.
Please let me know what is the right way to do it
Kind regards
Miche
You did power it on correct (Your drawing shows this disconnected)? Did you use an ammeter or oscope? What current did it observe? What is the current resolution and range of your application and the chip?
