How to connect the cable with the rs485 converter?
annix1121
How to connect the cable with the rs485 converter? is it directly connected to the terminal A and B?Im using the 2 core cable since my circuit design is a half duplex converter.As i know the there is 4 terminal for the rs485 converter, one is power supply, one is ground and left terminal A and B from the max487 transceiver.
Re: Connection of RS485
RS485 allow two-wire multidrop network, usually a ground line is added, You could find a good application note at link:
hxxp://bb-elec.com/tech_articles/rs422_485_app_note/overview.asp
1. Jumper the RxD+ and the TxD+ together and connect it to the RS485+
2. Jumper the RxD- and the TxD- together and connect it to the RS485-
Now the converter is also talking half-duplex like your device.
tom tran
The Online Pinout Project
https://rj485.com/index.php?main_page=pinout_db
Connection of RS485
For multiple nodes, the two wire network topology is the most popular design.
