Thanks for the answers. I know have also another problem. My project Design in QII has 4 files:
-eeprom32k.vhd (a simulation model for a eeprom)
-p2s.vhd (the synthetizable .vhd of a serial to parallel epprom converter)
-top.bdf (the top connection between the eeprom32k.vhd and p2s.vhd)
- testbench.vhd (the testbench that apply input to the top.bdf, it instantiates the top in the file).
My problem is that when if I use testbench as the top in the compilation hierarchy and make start->analysis and elaboration the shows
"Wait Statement error at testbench.vhd"
this is the line: wait for TCLK;
Is elaboration similar to synthesis?
I know that my testbench is not synthetizable but should I elaborate before simulation?.
Which are the steps to run model@im directly from quartus becuase in my case start the program all is ok but model@im does not get the correct hierarchy and I just see the command line. The testbench seem that does not run.
Sorry for hitting with so many questions,
thanks a lot and best regards,
mimoto
