I am needing to combine the local terrestre antenna with a (VHF or UHF) modulator on single cable. The modulator carries the CCTV signal from a multiplexer circuit.
How to do it ?
And how to project a video amplifier to VHF/UHF band in order to distribute the resulting signal to 10 differente locations ?
How to do it ?
To combine for different frequency signals, it should be used either duplexer or simple combiner. Here is , the most important thing is to avoid impedance mismatching and to procure isolation between signals.
For this purpose you may use lumped duplexer what has a low pass and high pass filters that are convenient combined.
Or..
Use simple ferrite combiner (or commercial TV combiners work up to 2150MHz very well ) .
To distribute TV signal on a same cable to different receptors, you should use modulators that are locked on different carriers. For doing that either use TV modulator IC ( TDA8822T of Philips, I2C Bus Multistandard Modulator) which will be very good project for you or use commercial modulator modules which are available from different brands.
If I were you , I make a project muti modulator in single case with a single microcontroller.It's a good idea..
why bother
just modulate the cctv signal to the tv band using a simple modulator
then it can be carried along with the tv signal as a normal uhf you can if needed for cctv monitors demodulate it and use tv sets instead
to connect the modulators together use a Tpad attenuator on both outputs
followed by a standard 10 or 24 ways distribution amp
i recomend something like 150 150 150 R to give 1 db level for the distribution amps input
however most of the better dis amps come with more than one input
