How to choose the correct diode?
ericmar
Full Member level 5
Singapore
how to choose a diode
As above. How do I know which type of diode I should use?
how to choose diodes
Where this diode will work ?
Write more information, your question is very general.
how to choose diode
You want the current rating of the diode to be utilized. For rectifier applications the current goes from zero to a specified current. The diode is rated for average current with the peak current being very high. The way I find average current is to take the sine wave and break it into 16 equal parts. The discrete voltages are then applied to the impedance to find the discrete currents. Add the currents up and divide by 16 to give you the average current. Remember that the current of a capacitor is still the voltage divided by the impedance.
choose diode
What are the working conditions you wish to put your diode into?
diodes how to choose
Maybe I should ask "What's a diode used for?"! Is it for limitting current only? I know it only allows current to flow trhough in one direction, right? What about Zener diode? I got a diode here labelled as 79 C6 V2, wat is it for? In fact, I'm studying on some circuits so I'm trying to understand why they used all these diodes for!
Thanks for help anyway!
how do you choose the right diode?
Diodes can be of different types. It could be rectifier, zenner, varicap, diac, PIN, LED, etc. Each diode type has it's own function in circuit and symbol in schematics. Get some knowledge about diode types and their symbols and the things when analyzing circuits will be easier.
how to choose a diode?
You can find some very good information on diode (e.g. diode ratings) and its applications (e.g. rectifier) here:
how to choose a correct diode
This is definitely a very good site for a beginner like me! Thanks a lot! :)
diode choose
depends on ur application........
Using Si (silicion ) diode , u can turn it on by 0.7 volts threshold voltage.....
If u require less on voltage for particular application use Ge(Germanimu) diode....It's on voltage is 0.3 volts.....but Ge diodes have less power handling capability than silicon diodes.............
Zener diodes employ the zener characteristic regiion for use in particular applications.....In zener diodes the direction of conduction is opposite to that of the normal diodes .........
