How to calculate the value of a capacitor to maintain VCCOUT
snoop835
Full Member level 1
Penang, Malaysia
Capacitor
Hi all,
As you can see in the attachment file, I tried to main the VCCOUT dc level when the input VCC droop to 0.5V and stay for few us and rise again to 1.8V. I used diode connected NMOS and capacitor so the VCCOUT = VCC - Vth. Can somebody tell me what is the equation to be used to calculate the value of the capacitor in order to maintain VCCOUT even when VCC has a droop?
Is there any other circuit that can perform the same function if not better since my circuit will have voltage drop because of the diode connected transistor.
I hope you guys can throw me some light on this.
appreciate any comments!
thanks
-snoop835-
Capacitor
I think the drop is due to the charge sharing to the parasitic cap. from the diode connected NMOS, in
one clock cycle
C*(1.8-0.5)=(C+Cpar)*VCCOUT_min
so if the C is much larger than Cpar, the VCCOUT
can be more close to VCC-Vthn.
Re: Capacitor
try to use tansmission gate raher than nMOS switched
Re: Capacitor
Hi syukri,
Do you mean replacing the diode with transmission gate...How to use transmission gate to replace the nmos diode connected? Pls elaborate....
appreciate your help.
thanks
