Recently we did 7 - Track height for standard cell layout for Ultra high density cells. Here I have clarifications on track width as you mentioned that track width equals to metal width is it metal 2?
Because in our design m2 width and spacing is equals to track width and spacing.
Could you explain more on how to calculate height of the cell?
I am not sure if this is correct answer .. but the height of the standard cell is fixed and we make all other cells based on this standard height . we use here ST cells .. and make all other cells based on this .. let me know if I am wrong ..
hi,
Usually , horizantal routing track width depends on (M2 min width)
vertical routing track width depends on (M3 min width) assuming VHV routing architecture..
Normally M2 & M3 will have same min. and max. dimensions
amara i am basically into DFT i u want more information u can reach mail id neethanac@gmail.com, this person working in the library development team ..
