How to calculate the capacity of a current transformer for a particular load ?
dineshdeshmuk
Full Member level 5
How to calculate the capacity of a current transformer (which amperage current transformer must be use with a specific load or amps) for a particular load ?
Dear dineshdeshmuk
Hi
Can you tell , me a bit more explanation , please ? what do you mean by capacity of current transformer ? are you referring to the allowed value of current ?
Best Wishes
Goldsmith
Check burden factor on CT secondary.
The knee point is defined as the point at which an increase of applied voltage of 10% results in an increase in magnetizing current of 50%.
Also alternative types.. Rogowski_coil
many types....
about the current transformer calculation ???
would you take any particular example and show me the steps required to do the calculations ? plz
i don't even know the types of CT , would you take each and every example of it ? plz
