how to calculate LUT usage in fpga design?
vsheladiya
Junior Member level 3
Hi All,
The logic count in a fpga/asic is considered as a number of 4-LUT usage now a days. I have doubt in calculating the number of 4-LUTs for any design, how can we calculate it? Is it depends on number of inputs or number of outputs?
Also how many 4-LUTs will be used if i design 16-bit shift register and 4-bit adder?
Thanks...
The system which you are using should generate some reports about the usage of a die, try to find it
Thanks Kirill for your reply...
That's true. I counted no. of LUTs by that way also. It is showing 18 LUTs and 16 FFs for 16-bit shift register. In that i got 16 no. of FFs but i didn't get how it is using 18-LUTs (4-input) for it.
Also the system should generate graphic scheme which will show you why synthesizer use 18 LUTs
Yes Kirill, I also refered its schematic and technology map viewer. but it is showing the design using different no. of input LUT not 4 input LUTs. I want to know how the tool is calculating resourse usage with respect to 4 input LUTs.
Synthesizer parses your hdl code and applies optimization algorithms(i suppose that you will not find any information which algorithms system uses) and than your combinational logic transalates into LUTs. LUT is like multiplexer and its inputs are address.
I know that LUT construction and its basic but i am not getting how tool has implemented it into 18 LUTs. which value it will store at which location? how many inputs are required for implementing 16 bit shift register? how many outputs are required? how LUTs will be connected to each other? I want to know these things...
Thanks
I think that hardly anyone can help you in why suthesizer translates in 18 luts not in 17, you work with final compiler and you can not change it, only input compiler parameters(hdl code, sythesizer options) affects on your result. And what goal are you seeking? You want to reduce usage of a die?) If no, never mind it
No i am not reducing die resources... I just wanted to know for my knowledge.
Lets take a small example :
If you have written the below code where you are trying to do XOR of all your 6-bit input vector
o/p = inp(0) ^ inp(1) ^ inp(2) ^ inp(3) ^ inp(4) ^ inp(5)
I wll split in to temporary signals to map in to LUT :
o/p1 = inp(0) ^ inp(1) ^ inp(2) ^ inp(3)
o/p2 = o/p1 ^ inp(4) ^ inp(5)
o/p = o/p2
you could see that o/p1 will be 1-LUT4 and o/p2 will be 1-LUT3
So in general u need 1-LUT4 + 1-LUT3
Let me know if you need further explanation
dcreddy:
same thing can you explain for 16-bit shift register?
TrickyDicky:
Actually this is for clearing a doubt not for perticular code. Then also you can consider 16-bit shift register as my code.
The thing is, code can be important. Ive just built the following shift register code and it uses 16 registers and 0 LUTs.
entity shifter is
  port (
    --Clock and reset
    clk                       : in  std_logic;
     a  : in std_logic;
     b : out std_logic
end entity;
architecture rtl of shifter is
  signal temp : std_logic_vector(15 downto 0);
begin
  process(clk)
  begin
    if rising_edge(clk) then
      temp <= temp(14 downto 0) & a;
    end if;
  end process;
  b <= temp(15);
end rtl;
So I wonder what you are doing.
i'm adding my code here and i have synthesized it using xilinx ISE tool.
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
entity shift_reg is
port(
clk : in STD_LOGIC;
clr : in STD_LOGIC;
data_ld : in STD_LOGIC;
data_in : in STD_LOGIC_VECTOR (15 downto 0);
shift_in : in STD_LOGIC;
shift_en : in STD_LOGIC;
shift_out : out STD_LOGIC;
data_out : out STD_LOGIC_VECTOR (15 downto 0)
end shift_reg;
architecture definition of shift_reg is
constant RESET_ACTIVE : std_logic := '0';
signal data_int : STD_LOGIC_VECTOR (15 downto 0);
begin
process(clk, clr)
begin
if (clr = RESET_ACTIVE) then
data_int <= (others => '0');
elsif clk'event and clk = '1' then
if (data_ld = '1') then
data_int <= data_in;
elsif shift_en = '1' then
data_int <= data_int(14 downto 0) & shift_in;
end if;
end if;
end process;
shift_out <= data_int(15);
data_out <= data_int;
end definition;
you mean to load data into data_out?
also which tool are u using?
Im using quartus - and for your code, I got 16 regs and 16 Luts - as expected.
The muxes are generated for the "if data_ld = '1' then" condition, as the registers should have a clock enable input. data_int is really just an imaginary signal that connects the data in to the data out.
Basically, the muxes chose between data_in(n) or data_int(n-1) for each bit, with the selection controlled by data_ld. This is where your LUTs are coming from.
Thank you TrickyDicky....
I got my answer.
Thanks again for your quick support.
LaTeX Commands Quick-Menu:
