How to calculate gain from radiation pattern?
cakalhunter
Junior Member level 1
how to calculate radiation pattern
Can anybody explain how i can compute gain from radiation pattern? I could not obtain a satisfactory solution for this problem.
Thanks in advance
plasma
Advanced Member level 2
measure radiation pattern
The gain G of antenna is a power ratio, function of directivity D and efficiency K :
G = K*(P max/Pin avg) = k*D (G is expressed in dB)
The directivity of an antenna is the maximum gain measured compared to its gain averaged in all directions. The directivity D of an antenna is given by the next relation : D = P (max)/ Pin (avg)
To compare performance of a 20 dB gain antenna over an isotropic, let's image that this antenna radiates its 20 dB gain (in fact 20 dBi) from the center of a sphere. This energy will travel through a surface 100 times smaller than the total surface of the sphere, or 41253squer° / 100 = 41squer° of beamwidth.
This calc. it's for 100% efficiency antenna
Dmax =4π/ΔΩ =4π/Δθrad1 Δθrad2 =41 253/Δθ°1 Δθ°2
Gmax =K/Δθ1 Δθ2
Practical
values of K fall in the range 25000–35000 (with the beamwidth angles in degrees.)
cakalhunter
how to calculate radiation of entana
My friend, thanks for your help
but is there a way to obtain gain from radiation pattern? All i have is a radiation pattern.
regards
svarun
Full Member level 5
Full Member level 5
In the warm company of God's most exquisite creati
how to calculate the radiation patterns
Let P(Θ,Φ) denote the far field radiation pattern with respect to power. You need to square if you have the field pattern. . Find P(Θ,Φ)max. Then find the average of P(Θ,Φ) by taking a grid of say 50 by 50 points or even finer. Find 10log(P(Θ,Φ)max/P(Θ,Φ)ave) That will give your gain.
svarun
snkhan
Full Member level 6
Full Member level 6
Gods place
svarun
Hi:
Please clarify the difference between radiation pattern and field pattern. Because we measure the field pattern (e.g. azimuth) in anheonic chamber which is power measurement.
dowjones
Full Member level 2
Full Member level 2
simply you can't.
from the pattern you get the directivity, which differs from the gain in the loss of the antenna. To have a measure of the gain you need a standard gain antenna and make a power measurement (which is out of your means if I understand properly), or an estimate of the loss of your antenna. Assumed this is the case, you have the loss (estimate) and the directivity (pattern), so you have the gain...
btw field pattern, radiation pattern is all the same.
rgdz
snkhan
Full Member level 6
Full Member level 6
Gods place
Hi
The definition given by plasma makes sense.
Actually measuring the radiation pattern using an antenna of known gain (usually horn antenna) is an estimation of loss in a specific plane. I think we can measure the gain by subtracting the gain of known receiving antenna to one obtained from above definition.
please let me know if i am wrong
VSMVDD
Banned
scotland uk
yes you can do this be measuing using a soft media like a snow material
or a terain that is a simulation of snow
you need nec pro this has such terrain sims built in
dont listen to no it cant be done
ANYTHING can be done in a simulation with rf
you just need to filter out the idiots first
simply put
you need a buffer media and detract it from real life terrain
this way you can duduce gain over a given terrain region
actual gain is given over an isotropic for a perfect sim
but i think this isnt what you want
so nec pro is....
