how to calculate axial ratio in hfss
Sika
hi,
I have simulated corner truncated inset fed patch antenna. It has good return loss at 2.45. Since it is corner truncated it should have circular polarisation. In papers circular polarisation is determined on the basis of axial ratio. They have the graph of axial ratio versus frequency. But in hfss for axial ratio we have to choose the report type as far field . and graph is plotted against only single frequency (2.45). So it would be of great help if you suggest how to determine the axial ratio or the circular polarisation in hfss.
