How to analyze Vout / Vin in S/H circuit ?
mpig09
Full Member level 4
Full Member level 4
Taipei
Dear all :
The attached file has two sample and hold circuit,
I try to analyze the Vout / Vin, but the result always
Vout / Vin =1.
Could you help me how to analyze the circuit ?
What parameter you want analysis? And what model of opamp you use?
For begining you can add input votage offset and changing sampling frequency. And what about pedestal error?
Dear all :
First circuit : C0=C5=1.2p
C1=C3=0.8p
Second circuit : C1=C2=1.2p
C0=C3=0.8p
Could anyone describe how to analyze ?
(analyze principle / formula)
Thanks for your kindly help.
mpig
Hi
sorry
I took a mistake.
draw half model of fully diff S/H.
charges in sampleing phase:
Q0=Vcm.C0
Q1=Vin.C1
charges in holding phase:
Qout=Q0+Q1=Vcm.C0+Vin.C1
Vout = (Vcm.C0+Vin.C1)/C0 = C1.Vin/C0+Vcm
VOdiff=C1.VINdiff/C0
C1=1.2p, C0=0.8p
VOdiff=1.5 VINdiff
regards
Dear hr_rezaee :
For second circuit :
Sample phase
Q0=Vin*C0, Q1=DAC*C1
Hold phase
Vout=Vin + Qout / C0
Qout=Q0+Q1
so, Vout=Vin+ (Vin*C0+DAC*C1) / C0
=Vin + Vin + DAC*(C1/C0)
=2*Vin + DAC*(C1/C0)
Is it right ?
mpig
Added after 1 hours 48 minutes:
Dear hr_rezaee :
Do we need to care +/- sign of capacitor charge in the first and second circuit ?
mpig
Hi
I think there is a mistake in second S/H.
I think path from input to output is extra.
If we remove this path we have:
Sample phase :
Q0=Vin.C0, Q1=DAC.C1
Vout=Q0/C0=Vin
I'm not shure this circuit is true.
regards
Dear hr_rezaee :
I use hspice to verify the gain result, Vout approaches 2*Vin - DAC*(C1/C0)
, I try to calculate this result, but the result is still not correct.
Could you have any suggest ?
mpig
Hi
could you attach an image that shows full circuit?
all switches and nodes.
regards
Dear hr_rezaee :
I can't show detail schematic.
I hope it is enough to help.
mpig
Hi
Sorry
I can't Understand.
If you can, draw better schematic
Please explain where you see this S/H?
regards
Dear hr_rezaee :
It is my project.
mpig
Hi
Ok, but you must have more detail about it.
such as type of S/H or references.
regards
