I am using TPS65100 (the switching frequency is fixed at 1.6MHZ) triple power supply chip, the problem is how I can analyze the signal integrity of my PCB including this power supply chip.
Re: How to analyze the signal integrity of PCB with power ch
Your best bet would be to use Hperlinx tool.
You can run an SI test/simulation on the critical signals that you are warried about by setting up your high frequency switching signal as an aggressor to the sensitive signal(s).
