Phosphorous
Newbie level 2
I have a D/A output from an audio card (DAC). The audio signal is AC-coupled so it has no DC component. I need to add a 0-10V variable DC offset, all to be controlled from a computer. This offset will be fairly static. IT will be adjusted to a value and left there for the duration of use or may be adjusted once or twice. I was wondering if this will work...
I plan to use a GE Fanuc (VMIVME-4514A) 16 channel analog output VME board for the 0-10V DC offset.
Will it work if I connect the + of the 0-10VDC signal to the negative of the output of the DAC, and then have the desired resultant signal be seen on the + of the DAC to the (-) of the 4514A?
Will this work or will I need (or want) some other circuitry or diodes for protection? Simplicity is key, cost is not important.
Thanks in advance!
Thanks in advance!
