How to add property to pcell?
tea_xiao
Newbie level 5
lvsignore
I have already completed a pcell with skill. Now I want to add property to it in order to avoid lvs check. It seems that I should use dbCreateParamInst and dbCreateProp to do it. But i don't know how to use them.
Who can give me some advice?
Hughes
Advanced Member level 3
<p:cell message properties
You may
Use cdsdoc (or openbook) and cdsFinder to find the usage of these two functions.
Or
Try to use pcCellView~>lvsIgnore="TRUE"
tea_xiao
Newbie level 5
dbcreateparaminst
I know how to the usage of these two functions.
But I don't know where I should add the two functions in?
*.il? *.cdf?
Hughes
update cdf pcell
In *.il. In the function body of pcDefinePCell.
ersachinkalra
Newbie level 5
pcell modify
Ya this is correct that you can specify the properties in pcDefinePcell function body...
but this will be a fixed value....in this way u have to change your skill file to change the prpperties of pcell...
For Automatic change of properties of Pcell you have to edit its CDF...
Go to icfb window and go to tools -> CDF -> Edit....
A form will appear...select Type Base and click on add properties....
here you can add any property you want to add..remember those are dummy names and values you have to link your skill properties to that in CDF....
If you have any query then you can mail me at sachinkalra1982@yahoo.co.in
ahmad_abdulghany
San Jose, California, USA
field dummy is not in form edit cdf form
In this case you have to have write permission on this pcell, otherwise, system will give you error message,
Regards,
Ahmad,
fathi
Junior Member level 1
lvsignore ture
I want to have parasitic capacitors be included in the schematic but that won't pass lvs then. Importantly, I implement some caps by metal layers, but then the schematic cannot have caps to pass lvs. I wonder how I can do that. I tried to add lvsignore to the cdf of the cap or pcapacitor, but it didn't let me do that as I can only open it in read mode. I wonder how I should do that?
Thanks a lot.
sandeep_torgal
Full Member level 2
icfb cdf edit
You can do it by editing it write mode only.. I dont see any other option
fathi
skill based pcells
It didn't let me edit it when CDF Type=base, but with CDF type=user , I added a parameter with following settings:
parameter type=string
name=lvsignore
defValue=TRUE
or
parameter type=boolean
name=lvsignore
prompt=lvsignore
defValue=t
but, then in the schematic, I can't specify the value of lvsignore; i.e., in properties:
under user propertiy: lvsignore
Master value (gray--> I can't enter the value)
Local value: checked
but still, it's not lvs-clean. I wonder if these settings are not right. Do I need to add or modify anything else?
Thanks a lot.
neoflash
Advanced Member level 1
Re: skill based pcells
I have the same issue. But I found people can add a user property in symbol view. But have no idea how?
name=lvsignore
defValue=TRUE
or
name=lvsignore
prompt=lvsignore
defValue=t
Thanks a lot.
