How to add a component from Xilinx Core Generator?
hqqh
Full Member level 4
Full Member level 4
how to add component from xilinx core generator
hello,
i'm using i/s/e5.1. i want to use a specific component from the xilinx core generator (dual port ram v1.0) but it seems that this component is not included in i/s/e (or not installed).
how can i add this component and where can i get it?
thanks in advance,
hqqh
All cores with docs are placed in $XILINX\coregen\ip\xilinx\primary\com\xilinx\ip\ and usually are installed with ISE. The verion 1.0 of Dual-port RAM core is obsolete and is not supplied more. Therefore you should consider to move to new version of core, or to old version of Xilinx Foundation or to ask somebody who has old version of Foundation to send you this catalog with old core and try to install it manually.
I would recommend the first way.
Ace-X.
I think you should get a core update packet from Xilinx if the problem you described was a version issue.
can you give me an example?
I think Xilinx IP core is very useful to development quickly. but i don't how to use it.
