How to access the USB port using MATLAB?
zeeshanzia84
Full Member level 3
Pakistan / Germany
usb access matlab
Can someone please tell me how to access the USB port using MATLAB? Is there some similar mechanism available like the serial class?
I am able to access it using Java, but I am facing some problems.
Thanks a whole lot in advance.
Re: USB1 access using MATLAB
Hello friend,
You see the attachment, it may help you for your application where it is required a USB interface with Matlab.
For more details kindly contact me.
Regards,
N.Muralidgara
MSRS, CRL-BEL
    V
I don't understand clearly ur question. U already had ur hardware and want to connect with Matlab, is it right? If ur question is that I can help u.
I already had USB Camera System and I connected to Matlab to capture and display image.
can you explain you question more clearly?
I think you need drivers for the particular device then you can use it
muralicrl said:
Hello friend,
Regards,
N.Muralidgara
MSRS, CRL-BEL
I want to do FFT of real time incoming signal and see the frequency spectrum using DSP6713 kit. Can you suggest some help?
Akr
hi, univer_solar
I am doing final project, and I want a code of interface between digital camera and matlab, and code for capture image from video that coming from matlab.
please send it me
thanks
Hi Arul
See the attachment on Matlab and USB communication details.
Regards,
N.Muralidhara
  • CREATEUSB.pdf
hi,i read from help in matlab...we need to register vendor name to open the connection btw the pc and usb?????????
can any1 reply pls
