How to access only 4 bits of microcontroller port in C
quris_terris
Junior Member level 3
bitwise operator +microcontroller
i m using port 1 of microcontroller n want to acess only four bits at a time without disturbing other four bits. I want to do this in C language.i want method which work on four bits at a time not one by one bit.
how to access bits in c language
On output, you fake this by setting the "undisturbed" bits to the values they already have.
If you want to access only 4 bits at a time then do masking operation by using BITWISE operators & (Bitwise AND) | (Bitwise OR) ....
for eg var=79
to use only 4 lower bits and the original no with " 0F " .
temp = var & "0F";
similarly for upper 4 bits use " F0 "
perhaps you can describe more clearly what tasks you're gonna perform on the port..
if your port is bidirectional (read+write), it is ok to read in 8bits at a time, modify your 4bits and write back 8bits.
