jshroff
Hi All,
I am attempting to learn VHDL using a digilent board and example and have a very basic question.
The code is ...
I am confused on how the PS2 clock debounce is done. They way I read it
Since Q2 is assigned the value of Q1 how would (Not Q1) and Q2 every take on the value of 1?
Thanks
Jay
The code is ...
-- Company: Digilent Inc.
-- Engineer: Claudia Goga
-- Create Date: 22:33:35 11/25/06
-- Module Name: PS2_Reader - Behavioral
-- Target Devices: CoolRunner2 CPLD
-- Tool versions: Xilinx ISE v7.1i
-- Description:
-- This module reads scan codes from the PS2 Port. Every time a
-- new scan code is entirely received it enables the fRd signal for one
-- main clock period.
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity PS2_Reader is
Port ( mclk : in std_logic; -- System Clock
PS2C : in std_logic; -- PS2 Clock
PS2D : in std_logic; -- PS2 data
rst: in std_logic; -- Reset BTN0
Ps2Dout : out std_logic_vector(7 downto 0); -- out data
fRd : out std_logic); -- data valid flag
end PS2_Reader;
architecture Behavioral of PS2_Reader is
-- SIGNAL and CONSTANT DECLARATIONS
--The constants below define state codes for the PS2 Keyboard
--reader using ONE HOT encoding.
constant idle: std_logic_vector (5 downto 0):="000000";
constant shift_data: std_logic_vector (5 downto 0):="000001";
constant check_parity: std_logic_vector (5 downto 0):="000010";
constant check_stopbit:std_logic_vector (5 downto 0):="000100";
constant frame_error: std_logic_vector (5 downto 0):="001000";
constant parity_error: std_logic_vector (5 downto 0):="010000";
constant end_char: std_logic_vector (5 downto 0):="100000";
--state register and next state register for the FSM
signal state, next_state: std_logic_vector (5 downto 0):=idle;
signal D_PS2C: std_logic:='0'; -- debounced PS2C
signal Q1, Q2: std_logic:='0';
--shift register; stores the received bits
signal REG: std_logic_vector(7 downto 0):=X"00";
signal ptysum: std_logic:='0'; -- parity sum
signal ptycheck: std_logic:='0'; -- parity check bit
signal cnt: integer range 0 to 7:=0; -- counter
--The attributes below prevent the ISE compiler from
--optimizing the state machines. The states will be implemented as
--described in the constant declarations above.
attribute fsm_extract : string;
attribute fsm_extract of state: signal is "no";
attribute fsm_extract of next_state: signal is "no";
attribute fsm_encoding : string;
attribute fsm_encoding of state: signal is "user";
attribute fsm_encoding of next_state: signal is "user";
attribute signal_encoding : string;
attribute signal_encoding of state: signal is "user";
attribute signal_encoding of next_state: signal is "user";
begin
-- MODULE IMPLEMENTATION
----------------- Sample Keyboard Inputs -----------------------------
debounce: process (mclk, PS2C, Q1, Q2)
begin
if mclk'event and mclk='1' then
Q1<=PS2C;
Q2<=Q1;
end if;
end process debounce;
D_PS2C<= (NOT Q1) and Q2;
----------------- Synchronization Process ----------------------------
regstate: process (mclk, next_state, rst)
begin
if rst='1' then
state<=idle; -- state machine reset
elsif mclk'EVENT and mclk='1' then
state<=next_state;
end if;
end process regstate;
-------------------- State Transitions -------------------------------
transition: process (state, D_PS2C, PS2D, cnt, ptycheck)
begin
case state is
when idle=>-- idle
if D_PS2C='1' and PS2D='0' then -- check start bit
next_state<=shift_data;
else
next_state<=idle;
end if;
when shift_data=> -- shift in data
if D_PS2C='1' and cnt=7 then
next_state<=check_parity; -- go and check parity
else
end if;
when check_parity=> -- check parity
if D_PS2C='1' and PS2D=ptycheck then
next_state<=check_stopbit; -- valid parity bit
-- go and check stopbit
elsif D_PS2C='1' then
next_state<=parity_error; -- parity error
else
end if;
when check_stopbit=> -- check stopbit;
if D_PS2C='1' and PS2D='1' then
next_state<=end_char; -- valid stopbit, end Char
next_state<=frame_error; -- Frame Error
else
end if;
when frame_error=> -- Frame Error
next_state<=idle;
when parity_error=> -- Parity Error
next_state<=idle;
when end_char=> -- end Char
next_state<=idle;
when others => next_state<=idle;
end case;
end process transition;
------Counting bits and registering when state=shift_data---------------
regin: process (mclk, D_PS2C, PS2D, cnt, ptysum, state)
begin
if state/=shift_data then
cnt<=0;
ptysum<='0';
if D_PS2C='1' then
ptysum<=ptysum XOR PS2D; -- calculating the parity sum
REG(7 downto 0)<=PS2D®(7 downto 1); -- shifting data into register
if cnt=7 then
cnt<=0;
else
cnt<=cnt+1;
end if;
end if;
end if;
end process regin;
------------------PARITIY SUM-------------------------------------------
parity_sum: process (mclk, D_PS2C, PS2D, cnt, state, ptysum)
begin
if state=shift_data and D_PS2C='1' and cnt=7 then
ptycheck<=(NOT ptysum) XOR PS2D; --parity check bit
end if;
end if;
end process parity_sum;
----------------OUTPUT ASSIGNEMENT--------------------------------------
Ps2Dout<=REG;
fRd<='1' when state=end_char else '0';
end Behavioral;
Thanks
Jay
