How the coefficients get updated in LMS adaptive algorithm ?
makanaky
Full Member level 1
I need to implement adaptive filter with LMS coefficient update algorithm , I understand the LMS equation is as follows :
h(n+1)=h(n)+muo*x(n)*e(n)
Where e(n) is the error between the desired signal and the filter output, x(n) is the filter input, h(n) is the coefficient vector
My question is , how come the coefficients are updated to different values if they are initialized by same value (zeros for example )
The above equation suggests that all the coefficients will be updated to same value every time
Can somebody please explain this to me ?
Thanks a lot
