Maloth Ramesh
Junior Member level 2
i have problem while simulating the pspice model of ir2136 and based inverter with sine-pwm technique with 20khz switching frequency first one is control circuit second one is power circuit
![Capture.PNG Capture.PNG](https://www.edaboard.com/data/attachments/53/53546-9823a646a85b8eca2ada1d4268ba2c27.jpg)
my problem is source voltage is short circuiting for a duration around 1micro second
the gate voltage is continually deceasing.
igbt type fgh40n60smd, snubber circuit diode is rhrp30120, zenor diode is 1n4744,
and the voltage across the ITRIP terminal is increasing within 500micro seconds of operation
thank you,
![Capture1.PNG Capture1.PNG](https://www.edaboard.com/data/attachments/53/53547-ab466784919811bf679ffa63f9491cea.jpg)
thank you,
