How much electricity is lost in transmission and distribution
PA3040
Advanced Member level 3
Dear All,
This is only for understanding purpose
Does it effect to the power source , if we use the transmission lost power for anther purpose,
Symptom
One of my friend who lights the florescent ( tube light ) lamp using lost power of mobile base station closed to the his home
Please advice
Yes. When I serve in army at night the florescent tubes give us Morse code from near room operators.
Unfortunately I still don`t know the Morse code. Is it good or bad:sad:
Unfortunately I still don`t know Morse code. Is it good or bad:sad:
I could not get it
PA3040, your friend should report this to the operator of the mobile mast, that amount of power should never be directed at any one place. There is something wrong with its aerial system.
If you are talking RF transmission, in London, there is a population of 12 X 10^6 with say, 4 X 10^6 TV sets. The signal strength for a good signal is 2mV across 75 Ohms, which is 4/75 X 10^-6 Watts each. So the TV sets are consuming 4 X 10^6 X 4/75 X10^-6 = 16/75 Watts ~.21 W, the transmitters transmit 80 KW, so RF power
transmission is pretty ineffective.
Power transmission at 50HZ is > 90% efficient.
Frank
If I'm understanding this correctly from the original poster, is whether he should be using the power from a RF transmitter to light up fluorescent tubes??
Is my understanding correct?
Dear schmitt
Thanks for the reply
This is the mobile telephone transmission base station ( GSM system ) I think 3G
I think you may correct but as per my friend, The lamp lights only very closed to the base station, what I am asking is, in this situation, does it effect to the transmission power of the base station
Please advice
Frank
Hi Thanks for the reply
As per my friend the lamp does not light at it max bright and the light we can see correctly at night time, as well as when we tough the lamp it's gets bright up
Please give your more suggestion
GSM base stations have antenna arrays that focus the radiated power to a narrow vertical range. Placing a receiver, e.g. a fluorescent lamp in front of the antenna would affect radiated power, outside the direct beam there should be no effects - and not much RF power available. Otherwise something is probably wrong with the antenna cabling, as already mentioned.
Reactions: PA3040
    PA3040
Dear FvM
Really thanks for the reply
if so, the power consumption by fluorescent lamp must be consume power of the GSM base station power supply. Am I correct?
Please advice
