samakbass
Newbie level 2
I have an Led with the following specifications:
3-3.2 V
Size (mm) : 5mm
Lens Color : Water Clear
Reverse Current (uA) : <=30
Life Rating : 100,000 Hours
Viewing Angle : 140 Degrees
Absolute Maximum Ratings (Ta=25°C)
Max Power Dissipation : 80mw
Max Continuous Forward Current : 24mA
Max Peak Forward Current : 75mA
Reverse Voltage : 5~6V
IF i use one LR41 battery connected to it, how long will it last? Do I really need to use a resistor for this setup?
If I use one LR44 battery, how long will it last?
If I use one CR2032 battery, how long will it last?
How can I solve these problems?
3-3.2 V
Size (mm) : 5mm
