deepakchikane
Full Member level 3
- Joined
- Jul 17, 2012
- Messages
- 178
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,298
- Location
- Mumbai, Maharashtra, India, India
- Activity points
- 2,623
The datasheet literally shows a gate drive circuit on page 6, along with a link to an appnote specifically on gate drive...
The circuit shown in the datasheet should be sufficient, but you haven't said exactly what you're trying to achieve (frequency, voltage, etc). You just need a standard gate drive IC, a current limiting resistor Rg, and a speedup capacitor Cg. This application note explains it pretty thoroughly, I don't see where your problem is...mtwieg..
it is too short to understand & also the application note is worth to drive this or simply it cant understand exact...
You mean dv/dt on the drain? Can you post your circuit?i designed the driver but there are too much dv/dt...
i have to slower down dv/dt
plz help out
