throwaway18 said:The advantage is that a shunt regulator can usually be designed to work with a lower voltage overhead than a series regulator, eg a typical 7805 series regulator needs Vin to be a minimum of about 3V avove the load voltage.
The disadvantage is that in typical applications shunt regulators.are less efficient than series regulators. More power is wasted as heat.;
To develop a voltage for the adjustable set-point, we used a 15 V, 1 W zener diode and a 4.7 K trim-pot. To calculate the series resistor for the zener, we just used:
VOLTAGE DROP (20 - 15) V
R = ------------ = ------------- = 250 Ohms. We used 200 Ohms.
ZENER CURRENT 20 mA
WATTS = (5V) x (5V) / 200 = 125 mW (Use 1/4 Watt)
and just use 5.1V 20mA zener
