How does standalone GPS receivers ensure an acucrate clock?
kel8157
Full Member level 2
I understand that for a cellular phone based GPS, one can calibrate the clock against the synch channel timing from the GPS/WCDMA to under 0.1ppm..
However for standalone GPS receivers, there is no cellular clock to calibrate against. How do the designer get arround that?
Mityan
Full Member level 5
For GPS receiver there no cellular clock, but maybe there is a space segment - the network of satellites to calibrate against, how you think? It just receives their signals
kel8157
Full Member level 2
my understanding is an expensive TCXO is used to calibrate against cellular clock, then used to receive the GPS signal.. so before the GPS signal is received and decoded, how do you ensure the clock is good? GPS signal itself suffers doppler, atmospheric distortions and many more..
Mityan
Full Member level 5
Your understanding is not right.
The GPS receivers are very cheap, so they dont have a good TCXO. They extract time info from navigation data, but before this they syncronize with the system by receiving the code (C/A for civil, P(Y) for military). 1.023 MHz of C/A code provide 1 us precision but in general much better is achieved.
If you know what time is it now and where are you then you know doppler shift for every satellite because they accurately move on the definite track.
If you dont know your position and time you should find the right satellite signal by looking all over the possible doppler and time shifts (ambiguity function 2D).
All other distorsions are overcome by pseudo random code accumulation.
RCinFLA
Advanced Member level 2
GPS receivers have a pretty good TCXO. Usually they are +/- 0.5 ppm spec which are better then ones in most cell phones.
The TCXO does not run continuously and when the GPS receiver is off, the time keeping is a standard 32.768 KHz crystal just like in a PC or digital clock. These are about 100 ppm accuracy.
GPS has many levels time keeping that can accelerate lock times. The first level is being able to predict what satellites are overhead therefore being the best bets to run the correlators against looking for their PRN code. If location is changed significant, like flying on a jet plane to another continent, then this predictiion can actually degrade lock time because many of the satellites may not be in view causing the correlator resources to be wasted.
Part of the satellite location prediction involves setting expected frequency Doppler shift. There can be as much as +/- 3 KHz Doppler shift for satellite coming or going over the horizon. For 1575 MHz, that is equivalent to +/- 1.9 ppm offset in frequency. The digital correlators have a limited frequency lock range of between 300 to 500 Hz so the receiver must 'tune' frequency bins by moving the synthesizer across an assumed frequency error range based on estimating satellite location. If not finding lock after doing all the frequency bins, the software may assume the satellite is not there and may move on, allocating the correlators to another satellite. The worse the time accuracy, the wider the frequency search range must be because of the inaccuracy in predicting the satellite location and its frequency offset.
A GPS receiver keeps track of the last time it was active and computes how wide the time inaccuracy may be based on the 32 KHz clock error. It will widen out its frequency search range the longer it has be turned off to account for the possible time error. This can lengthen time to lock.
For a CDMA cellular network with full GPS assist, satellites visible, precise time to <1 msec, and frequency AFC is used to achieve almost instantaneous lock on satellites. If absolute time is known to better then 1 msec along with satellites health then the GPS receiver does not have to demodulate the 30 baud data which can take several minutes to derive all necessary information to lock on to other satellites. The correlator bandwidth can also be reduced to improve sensitivity.
Newer GPS receivers have more channels and correlators so they can search for more satellites simultaneously and spread more correlator 'traps' over time and frequency to speed the lock process. Tightening down the correlator bandwidth improve sensitivity but increases the number of frequency search bins. Having more correlators offsets the downside of larger quantity of freq search bins, speeding the searching process while accomplishing improved sensitivity.
kel8157
Full Member level 2
Yes, i understand the correlators used to find the satellite etc, the bigger the TCXO deviation, the longer time one needs to search for the visible satellites..
And thanks RC for the explanation. :smile:
